it doesnt look like a abd car, but by lowering it, tinting the glass blue and painting it flat black its not going to be a rat rod. id like to tell you what it will be but that wont be nice so ill keep my comment to my self. if it was mine id convert it to big bolt pattern with 15" steel wheels painted white, some 225 or 235s all around the same size all around so you can rotate them and carry 1 spare, short enough to clear the front, yet wide enough to stick around turns. id put some big fat t bars in it, 920 or better and maybe some heavy duty springs with good shocks all around and front sway bar. it would be functional and work way better than a so called "rat rod" with no suspension that is going to ride like a garbage truck and wont align. i too like my cars a little lower than stock, but i remember seeing darts slammed on the ground all the time back in the day and it was because the t bar socket rotted out or becaus a ball joint let go, not because they worked better that way. if you want your car to look like a broken *** old dart that you threw some black latex house paint on, go ahead, its your car.
