I had a fast ratio (20:1)P4007612 kit installed and the splined end of the shaft does not have a flat to locate the coupling. Is there a special coupling for this upgrade?
Welcome to FABO! I haven't heard of any special coupler for the 20:1 worm gear. You may just want to center everything and grind one yourself to match yours. Good Luck!
