Al T
I recently purchased a '68 Barracuda convertible and am trying to chase down a non working temperature gauge and gas gauge.
Step one. Take a driving car with a couple of faulty gauges to this.....
I've got continuity from the temp sending unit to the round plug on the back of the gauges and I've checked the resistance at the sending unit and had 193.5 ohms with it cold and 22.8 ohms with the engine at 160F (checked with an infrared gun) so I believe it's OK. I've measured the resistance across the gauge and have around 15 ohms.
For the gas gauge I've got continuity from the sending unit connection to the round plug at the gauges and have checked continuity on the circuit board. I've got a good ground between the sending unit in the tank and the car.
I've got power at the black wire terminal (K position) on the round connector which according to the schematic is the feed for the temp and gas circuits. The previous owner had installed an aftermarket 4 volt regulator that when I pulled the dash out wasn't connected.... and the wiring on the round plug was as it should be for a stock system so it should have not had any input to the issues I'm having. It's all been removed and as far as I can tell, the wiring is as it should be.
The more I read about it, is it possible the regulator in the gas gauge is the issue? Is there a way to check it with caveman electrical testing equipment? The other thing I don't understand is on the printed circuit board, how does the black wire feed power to the temperature gauge? I don't see any physical connection between the two. Should there be a jumper wire?
I've got the gauges set up on a spare circuit board and still have no movement on either gauge.
Any advice/insight would be appreciated.
Allan
Allan
