68 Heater core Barracuda
Joker13
South Jersey
When I purchased my 68 the owner had tried replacing the heater core. It has been out of the car for the 2-3 years I have had it and I finally have gotten around to doing it.
Here is the run down:
He removed the entire assembly and ordered a core but it didn't fit. Ordered a second, same thing, so he just left it as is knowing he was selling.
Here is what I found:
The two new cores basically fit, but the metal tabs on them are slightly too long and keep the box from fully closing. I figure I can file or bend them to get the box to close.
I do not think he gave me the clips the close the box. I saw some on ebay- any recommendations?
One of the new cores has foam on the two long sides of the core. I then saw there is a heater box insulation kit. Should I use one or does that not matter?
A piece of the box broke off, maybe 3" x 2". It fits back in perfectly. Should I specifically use a fiberglass mending product or will anything work?
Anything i should do to the box while it is out?
as always- Thank you for your help
The foam could prevent a vibration noise and/or prevent air whistling around the core.
I think most any glue would work at case repair. I like Devcon Home 5 minute epoxy for it's 5 minute work time and low odor. Some of the 2 part epoxys really really stink !
This case might be a good place to try that new UV light activated adhesive.
Walmart has 5 Second Fix brand on their "seen on TV" shelf ).
