thanks. the cluster is in amazing shape. no chrome flaking or scratches. only thing it needs is to get some dust off the inside of the lenses and clean the electrical connections since i'm exiled in the houseyour car is coming along great keep it up.
not bad so far. i didn't buy the whole kit from Vintage, with the hoses and vents, just the Gen IV evaporator, controls and compressor. i wanted to get the unit and condenser installed before i decide how to run the lines. instead of hoses everywhere i want to do hard lines with more of a factory look to get a cleaner install than my 74 ended up withGreat looking project. Has the vintage air been a pretty straight forward install? I want to put one in my Valiant as well.
also going to try and plumb the outlets to the stock under dash vent i picked up. so far the only thing i don't like is the use of self tapping screws into the cowl area to help support it. i don't have a pic, but beside the fire wall bracket, i fabbed another one that i welded to the inside of the cowl behind the glove box area. hoping next week to get the rest of it installed
i ended up cutting the arm off the lever and welding back on the top side of the bracket
ha, i've seen your 68' build thread. lazy you aren'tThat'll work, I'm just a lazy bugger so i'd mount them in the lower half so I didn't have to make all the angled cups![]()
good info on the JB weld, i haven't used it in years and didn't even think about it. wrinkle black was the plan. i'd say something about great minds thinking alike, but don't want to drag you down to my levelJB Weld works well and you can sand and paint it.It kinda flows so You will want to keep it upright till it hardens. Wrinkle black will look great on that.
Just wanted to share a few photos with you. Got my 63 road worthy.
at least you're keeping my thread alive. i'm the one not doing my partSorry about the high jack. Carry on ....![]()
