[Found!] 7” round led headlights
coloradohill
Northern Colorado
I have a set of HWSTAR IP67 7” round led headlights. They are compatible with jeep and other Mopar vehicles. From Amazon description;
HWSTAR 2023 Upgraded 1000% Brighter Anti-glare 7 Inch Led Headlights Round Compatible with Jeep Wrangler JK JKU TJ LJ Chevy Ford GMC Dodge Mazda Nissan VW Mack etc DOT H6024 Hi/Low Sealed Beam (Pair)​
I installed them on my 67 Barracuda for a short time. Probably less than 15 minutes run time to adjust the aim only. They fit but I had to use longer machine screws and washers to shim the retaining ring out approximately 3/16” (5 10/32 flat washers). They are very bright. I decided to stay with a more sealed beam look. Link to their website.
HWSTAR Led Headlights | Illuminating Your Path with Excellence
New cost is right around 99.00.
Asking 70.00 shipped in the lower 48 tracked and insured from 80534.
