Sep 10, 2023 #1 A autumn ash Well-Known Member Joined Nov 13, 2022 Messages 80 Reaction score 17 Location Texas How much should i put in. I put in a quart already. Cant find an answer, some are saying 1 quart some 1 1/2.
Sep 10, 2023 #2 jawbone Cuda_queer FABO Gold Member Joined Mar 17, 2017 Messages 1,043 Reaction score 438 Location Richardson, TX Fill to bottom threads of plug.
Sep 10, 2023 #3 Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 8,721 Reaction score 15,479 Location Wisconsin Fill it until it just begins to run out of the fill (level) plug.
Sep 10, 2023 #4 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,140 Reaction score 16,532 Location Northern Colorado Refer to the FSM. 2 pints is 1 qt When I filled my 8 3/4 (clean assy no gear oil in the housing or center section) It took 5 pints to get to the drain plug. FSM says 4 for capacity. but FSM also says... Last edited: Sep 11, 2023
Sep 11, 2023 #5 jawbone Cuda_queer FABO Gold Member Joined Mar 17, 2017 Messages 1,043 Reaction score 438 Location Richardson, TX Dana67Dart said: Refer to the FSM. 2 pints is 1 qt View attachment 1716140106 Click to expand... Over the top response.
Sep 11, 2023 #6 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,140 Reaction score 16,532 Location Northern Colorado jawbone said: Over the top response Click to expand... OK?
Sep 13, 2023 #7 jawbone Cuda_queer FABO Gold Member Joined Mar 17, 2017 Messages 1,043 Reaction score 438 Location Richardson, TX Dana67Dart said: OK? Click to expand... Great info. Click to expand...
