[Found!] 70-76 floor shift column collar
lv6spd
Active Member
Nevada
I am looking for an a body floor shift column collar. The column I have is out of a 1973 but I don't care about the lock mechanism so anything from 70-76 should work. Thank you
I have a couple of the floor shift collars with the key lock if you still need one.
Ken
Edison, NJ
All three pieces for 71-76 with depress collar, Spring included. $90 shipped lower 48. I have several .
1970 is different it has a collar that is attached to the shift linkage so the trans must be in neutral on automatic cars and reverse on manual shift cars to remove key. PM for phone # pay pal accepted
