70 dart 340 4speed fan
Jarod340
Active Member
Petaluma, ca
I'm trying to figure out what's the correct fan,on my 70 dart 340 4speed car w/ no AC. I have a 5 blade fan and a 18" fan with 7 blades...
N51 cooling option?
Mine has no numbers but it has a pentastar and looks the same. Besides someone removing the clutch.
They move lots of air and run quiet too.
Had a 6 blade solid mount on a 74 Dart Swinger AC car. That fan made so much noise when it would spin up it sounded like there was a Prop Airplane under the hood.
So yeah, when you got one that runs quiet that is pretty darn nice.
That looks like a Clutch Style Fan with an Adapter to make it a solid mount fan, not sure why someone would want to do that . . . if anything I would think you would want to go for the Clutch.
Absolutely. Just removed the adapter and will search for the correct clutch tonight.
What engine, what car??
Small Block, Big Block ??
Here is the fan clutch I used with the 69 small block 318 (Red) above.
Have a part number too for that real short fan clutch if it is too close to the radiator.
Gee, by the looks of that short adapter think you are going to need that short fan clutch.
