71 cuda resto.mod ! 5.9 and efi + overdrive 12.99 ??
ValerianMagnum
the little car that could
montreal , canada
Hi Guys ! - heres my restomod ( DAKOTA RT 1999 swap ) - octane : 87-89 , street car, not racing -All mods , 3300 lbs car , 15x6.5 wheels , windage tray , vrp plates kegger mods short runners, wedge utawesome intake separator , stock ported throttle body , light bowl work on stock heads , running stock iron manifolds , stock compression, 360 car and 360 sump pump , stock 5.9 magnum camshaft , Stock rockers, stock pistons , stock crank and rods.....stock ignition and wires, plan to put the car between 3000 and 3300 pounds , dual exhaust 2.5 inch no cats , stock fuel system , 3.91 gears and 46re stock for now but planning a transgo shift kit soon *stock converter , cold air intake. ****overall should be 300 hp and 400 torque @ flywheel at 3 000 race weight with a good rear gear and traction ! I think it can do 12.99 !!! , i want a driver that looks factory stock but that has all the modern stuff and reability.What do you think !
