BigBlockMopar
BigBlockMember
The grooves are believed to help prevent detonation.
At first the general idea was the grooves, as the piston comes up to the heads BTDC, provide a 'jet' of fuel mixture from the closed part of the chamber, directed to the sparkplug to increase cylinder swirl and promote fuel burn.
It's now also believed it helps the compression pressure to get into the closed chamber part, again helping combustion.
This is all thought to be mostly beneficial at lower rpms.
