97reddodge
i have an 71 dart and im doin a disc brake swap off a 74 scamp neither car have sway bar mounts? what can i do to add a sway bar front and rear? i am also swapping the rear axles? thanks
It sounds like the sway bar tabs are the same on all LCA's that have them. I have a 73 car, with 73-up LCA's but an earlier 70's k-frame and what I think is an early sway bar as well. So my question is which end links do I use? 73-up, or earlier?
