Hi i put a set of used mopar super stock springs and front hangers on it. The problem is the springs pushed the axle back and the rear wheel is about 1/8 away from the rear fender and rubs when I turn. the front has over 2 inchs of space. The springs and hangars were off a 69 dart. Should I use my stock shackles they are shorter and might pull the axle closer to the front?
