MrTwister
On our ‘71 duster we’ve been trying to diagnose an issue where the fuel gauge reads full and after driving for a short while it’s already down to 1/2 or 1/4. We thought it might be the sending unit or gauge but when going to fill it up it will only take about 4-5 gallons before gas comes up the filler neck and the gauge reads full again.
From what we’ve seen so far this is not the original tank, the replacement tank didn’t have the 4 vents that hook up to the vapor separator in the trunk and those tubes were cut. Our original plan was to just replace the tank again but wanted to make sure we wouldn’t have the same issue if it was a venting / pressure problem since the filler doesn’t look like it has a vent tube in it. Any thoughts for best plan forward?
