I havent decide to use either trans for 70 340 duster it now currently 3.23 sure grip factory I have 2.47 to 1 need to be rebuilt or go with factory 2.66 to 1 ?
I agreethe ball and detent side cover is best one. mopar says to use it versus scissors style,
Small spline is 23 spline input. Large spline is 18 spline input / Hemi 4 spd.That would be the spline-count on the output end of the Mainshaft.
A-body
A833 overdrive boxes can be found at Swap meets in either flavor.
the slanty-boxes have the 904-sized shaft.
the 318 boxes can be found in either 904 or 727 sized shafts
As to Non-od boxes, IDK but;
All performance V8 boxes have the 727 sized shaft.
As to non A-bodies, I think they were all 727-sized.
Weirdly mine has the 30 spline output even tho its a 68 Dart A833... Is that odd?
Zero. If it’s an A body 833 it’s a few inches shorter than a 727.Seems 67 A body would be 26 output, and 68 up A body is 30, based on what i read on Brewers.
My car is a 71 Duster with 71 small block K, 440 using Schumacher mounts and 727 trans. What are the chances that my driveshaft will be the right length with the A833 that is going in?
