72 A body door fasteners
Newf
Edmonton
Hi all,
I have a partially disassembled 72' Demon, I would like to put the doors on it before I do any quarter panel/rocker removal to check alignment. The problem is that I am missing the fasteners for the doors. Anyone know what size and grade bolt would work as a replacement?? I'm guessing hot dipped galvanized would be the way to go as far as coating. your thoughts?
Thanks,
Joe
3/8-16, grade 5, about 1-1/4" long, and factory bolts had an integral lock washer.
Grade 5 really isn't necessary, but thats what I'd use.
Geo
3/6-16, grade 5, about 1-1/4" long, and factory bolts had an integral lock washer.
Geo
Thanks, a little confused though. 3/6-16 is that 1/2'' dia -16 threads/inch??
Anybody??? I really don't want to run a tap through the door threads to check it in case its wrong.
