72 Scamp front drums
I used to run 10" drum brakes all around with a hi-po engine when I was young. It tended to fade when using the brakes a lot as drums just don't dissipate the heat as fast a discs. With that engine, there is more weight and plenty of torque to manage, and I'd seriously encourage you to convert to at least the 73'-76' 11" discs up front. (Requires some parts changes; there are lots of threads on this.)
By 1973 -- 99 % were FRONT DISC Brakes -- and the Rears got the beefed up BBP (big bolt pattern) where they changed from 5 x 4" to 5 x 4 1/2" and changed
from 10"x 1 3/4" to 10" x 2 1/2" in the Rear....
If YOU -- or anyone you know -- has 1973 - 1976 Front Drums ---- I have those FRONT HUB & DRUM Assemblies -- NEW N.O.S. in the MOPAR BOXES --- and will
offer them VERY Inexpensively!!!!!!!!!!!!!!! (They ARE very heavy however -- and DO NOT fit in "if it fits it ships" boxes) !!!!!!!!!!!!!!!!!!!!
