72 swinger
finally car on the road,feel good! need some small things, rear shock bottom out,leaf spring are worn flat,no more arch, front summit wheel 15x7 have about 1/4 too much offset on front tires touch fender lip.maybe will go with my first choice 15x4 in front .need to fit correctly tailpipes.car sits really low also, the front lower bump stop do not fit.so will have the rear re arched or simply change the complete leaf with mancini or something like that ,and raise the front end.
someone have height from front fender lips to ground
after 4 years! still got the car . update on this tread
360 is in, floor shifter was column car, new steering box and 2 new pump! 3,91 in the back easily spinning the soapy 275 t/a!
running on the strip the car has go 13.20@ 101 mph best .i put a rpm intake and a gm hei but still exact same time!! will work on these .
just instaled some prw roller the new ones and if fits so good! stunning!!
I enjoy the car most on trips put some bucket seat from a vw that made the ride so fun!
will put some more picture
vw eos seat the mounting was around 19 inch wide,mounting them with bracket was a little tricky. the seat is adjustable on height but is still higher that i wanted , centering it the with vw bracket/slider go about 1 inch inside the oem bench seat hump (where the bolts go) I used all the vw slider bracket and made a bracket that bolt too the stock bucket seat hole on the floor, i will rework them to sit lower
update. I am here each week!
So today ,removing the eddy carb ,carter fuel pump and regulator to install the new avenger and holley pump it sit so high! Already have a drop base air cleaner. And a 3/4" spacer ..linkage is hitting the base.
Also have to clean up the msd wiring and I think I will install the box in the glove box ?
