AdamR
Big Member
Having issues with my Thermoquad so I took it apart which I should have just done from the beginning. Some junk in it but not to bad looking. Something is gummed up some place though. One side of the squirter has a heavy stream, the other side not as much. Also the mixture screw on the side with the heavy stream wants to be backed way out.
Took the carb apart and soaked everything in evaporust. I'll pick up a kit today but Im gonna need a secondary throttle shaft or a real small drill bit. One of the screws broke. I almost left the throttle shaft in but it seemed a bit sticky so I pulled them.
