[Found!] 73+ Front Drums/Hubs 10" x 2-1/2" SBP
DailyDriverDart
Active Member
Near Seattle, WA
Rating - 0%
0   0   0
Hi all,
Looking for a couple 10" x 2-1/2" front brake drums/hubs to keep our beater/daily-driver on the road. Existing hubs are loose on the outer bearing races (presumably from previous spun bearings).
Car is 1973 Dart Custom 4-door w/225 & TF904, drums all around, small bolt pattern.
Thanks for looking, Mark.
I have some hubs from a b body that had 10x1.5 brakes not sure if they are the same.
Hi halifaxhops, and thanks for the reply.
My research indicates the drum/hub assemblies I'm looking for are common only to 73-76 Dart and Valiant, but I haven't been able to come up with a part number for just the hub since the part book only lists them as an assembly (part #3699614) with the drum.
Perhaps (time/weather permitting) I may disassemble enough to look for a casting number or some such on the hubs next weekend.
Thanks again, Mark
Thanks again, Mark
I have some off of a 74 but can't disable the car just yet. How much of a hurry are you in?
OK now I feel REALLY picky - turns out we also have 7/16"-20 studs (rather than the apparently also used 1/2"-20).
I had no idea there were so many variations... (smh).
Hi all,
Picked up a lot of A body parts . i am sure there are hubs in the lot. PM if still needed.
all the ones ive seen are 7/16ths as well
heres one of the ones I have
