Johnnythunder
New Member
Hi folks, I have a 74 Plymouth valiant 225 slant 6 auto. Before I bought it, my friend put in too big of an alternator and it burned up the wire to the ammeter. I replaced the wire and worked out the bugs over the last 6 months. I replaced the ECU then within a week it died, so I replaced the big alternator with the stock alternator from a wrecker, replaced the battery,voltage regulator, ballast resistor, coil, cap and rotor everything except the ECU because I just got one. It would turn over but not fire. So I got another new ECU,voila it ran and drove fine for a couple months, fast forward 2 days ago. Wife goes to start it nothing, battery is dead, so I charge the battery put fresh battery in and the brake switch was missing the pedal, keeping the lights on (the reason the battery died I think) I tweak the brake switch bracket now the brake lights are off, start the valiant, warm it up and I'm about to take off I turn on the headlight and instantly the car dies. Now it won't do anything, no click no dash lights no headlights,dead nothing, fuses are fine, but if I jump the starter relay it will turn over. I'm thinking shorted ignition switch at the key or some sort of short in the dash or cluster. I was thinking chewed wire from mice maybe, but the headlights worked fine till the other day...Any suggestions?
