'74 Scamp
Kegan B
IN
318/904. New cam(Comp Cams Thumpr)
11-jpg.1714615489
6-jpg.1714615490
7-jpg.1714615491
5-jpg.1714615492
5-jpg.1714615492
10-jpg.1714615493
9-jpg.1714615494
8-jpg.1714615495
Keystones! I like it-looks like the metal work required is much less daunting than the Duster-does it run?
WooHoo, another Scamp! Tell us more about her.
Ok. All #'s match on the car. Stock 74 long block aftermarket valve covers( will get replaced by 80s chrome DC ones). Performer RPM intake, Eddy thunder series with manual choke. stock 904. 8 1/4. Got some spare wheels with it.
KEYSTONES!!!!! I have em on my 73 duster! Good luck and have fun with it!
i have maybe $5 and 1hr in mine (outta the '73 Duster). I plan to make a mad dash tomarrow night after I get home from school and get it most or all the way done.
Got it running better. Figured out why the torsion bars are cranked up tires slightly rub.
Glad it's running better-sucks on the tires though...where do they rub? directly at the top? when you turn?
VH23:
Plymouth Valiant,Duster
High
2 Door Hardtop
G4B: 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL
1974
Dodge Main, Hamtramck, MI, USA
123456: Sequence number
E44: 318 cid 2 barrel V8 230hp
D34: Light Duty Automatic Transmission
KY4: Golden Fawn Exterior Color
E2Y3: Trim - Unknown, Vinyl Bench Seat, Gold
000: Full Door Panels
402: Build Date: April 02
123456: Order number
KY4: Golden Fawn Top Color
U: USA Specifications
B41: Front Disc Brakes w/Standard 10in RR Drum
G51: Lt outside manual mirror
M21: Roof drip rail moldings
M26: Wheel Lip Moldings
M38: Decklid Finish Panel Moldings
N76: Coolant Recovery System
R11: Radio Solid State AM (2 Watts)
V6X: Longitudinal Stripes, Black
L1: bench seat with headrests
556: Probably a label pack
