[Found!] 74 Swinger Upper Control Arms
They are like $150. How low of budget does he have? You will spend $85 on used ones that still need ball joints. Take a step back & rethink new.
Or discover used were bent in a wreck, or need to weld the ball joint in.
Doctor Diff ones are Awesome. Bushings & Ball joints installed. Perfect paint job. Bolt it on & your done.
If they will work, I don't know. But I have a set of UCA's from a duster, 70 and another set from a 73. You can have them if they will work.
