If your RARE Dart Lite was built from 01/01/1976 and later , it'll have the excellent single piston disc brakes ; if it's an earlier build it could have those held-over delicious drums or those fantastic , held-over 4 piston K-H brakes .
Incorrect. All A-bodies with disc brakes got the single-piston variety starting with the first of the '73s (built in late '72). All '76 A-bodies with disc brakes, starting with the first ones built in late '75, got the 2.75" caliper bore rather than the '73-'75 2.6" caliper bore. All '76 A-bodies built on or after 1/1/76 got the disc brakes as standard equipment (from start of '76 production in 9/75 to 12/31/75, discs were optional)
These cars were capable of 25-30 mpg when they were new; and with modern tyres and synthetic lubricants ( don't forget to add ZDDP to the motor oil !!! )
You don't need to add anything to the engine oil; the ZDDP "crisis" is as overblown as the leaded-fuel "crisis", the R12 "crisis", and other similar "crises" hyped up to sell product. There are those who feel otherwise.
The 4 speed in 1976 MoPars is an aluminum case
Most of them were aluminum, yes, but there was a casting porosity problem that made an ugly appearance; trans lube would leak
through the housing and onto the garage floor. Production switched back to an iron case briefly, and a fair number of aluminum-case A833ODs were replaced with iron-case transmissions under warranty.
If your car has that stupid , 100% worthless 7.25" diff , dump it
That's not very thoughtful advice. The 7¼" diff is certainly weaker than the 8¼" unit, but it's not like the 7¼" is a ticking time bomb waiting to grenade and sideline the car. They work fine for low-stress street driving; millions of A-body owners have put millions of miles on 7¼" rear axles behind slant-6s and mild V8s over the years. You'll break it as soon as you start doing neutral-drops, or if you put a big, torquey engine in front of it and go racing. But there's absolutely zero need or call to spend money, time, or effort on the rear axle
just for the sake of swapping the rear axle.
2.71's are the most common gearset w/ V8 , and 3.21's with a Slant Six
2.7 ratio with slant-6 and automatic, making that the most common ratio with the six-banger. Stick-shift slant-6 cars got 3.2 ratio.
