[Found!] 8.25/9.25/8.75
12many
SC
Looking for a complete rear end to fit a 78 Magnum, preferably a 9.25" with 3.21 or lower (open OK) or even an 8.25 with 3.21 or lower. 8.75 open with highway gearing is an option. Gotta bolt right in (aside from enlarging spring pad holes for isolators) Ideally located is the southeastern states. Thanks
I have an 8.25 out of a 74 roadrunner with 3.21 open I'll take 50$ for.i think its a direct bolt in,but not positive.
It's located in albemarle n.c.28001
12Many might want to check this out.
It would be if the rear end has the ISO mounts. A rubber pad on each side of the leafy spring that gets sandwiched by metal plates.
Like so below on my ‘79 Magnum.
I have the shock plates and sway bar mounts too all for 75$ listed on craigslist in charlotte or greensboro n.c....i only have 1 of the rubbers tho.
Gear is beautiful,housing looks ok but needs some cleaning.
Going from a 2.45 to a 3.21 should help liven things up a sidge in a Magnum?!! :eek:Ready to come snag it.:thumbsup:
