8 3/4 big bolt pattern brakes
dart67
NH
If going from small bolt axels to new big bolt axels in an 8 3/4 what do I use for backing plates and brakes?
Thanks
Any big bolt backing plate/drum combos will work. I have found sets in the self serve wrecking yards around here with new shoes and just swapped them over.
Thanks
When ordering your axels,let them know what size brakes you already have(I,m assuming 10x 1 3/4??)They will make the axels to match your backing plates,brakes.Good luck.
