[WANTED] 8 3/4 hardware and cragar lugs
discharger1332
silverdale wa.
I’m looking for a few axle stud’s and all the nuts for the center section
Also looking for 10 rh lug nuts for cragar ss wheels with.59 shank diameter
I ordered new lugs but they are too big for the wheels.
Thanks for any help
dr diff has the nuts and such
i *think* the cragar lugs are fairly specific to cragar and they may be the only supplier? there was a thread about it on here not too long ago...
I advertised some Neversold them
Had 5 lh
9 rh
Not gonna give them away
are you needing 1/2 in or 7/16, I might have some 1/2 x 20 for the unilug type cragars, I'll check tomorrow. You might try lugnutkings that's where I got mine.
I need 7/16-20 rh threads.
The small bolt pattern cragars require a lug with.59 diameter shank. Standard cragars use .68 diameter shank.
I have the little small diameter Shank lug nuts for SS Cragar small bolt pattern I'm also looking for two center caps for small bolt pattern cragars maybe we could trade up something
Love those tall belted 14 inch tires look to be about 27 and a half inches...really miss em...coker has them for $278/each...pie crust style
I have the 10 3/8-24 nuts that go on the studs that hold the center section to the housing if you still need them.
Ken
Edison, NJ
Thanks for any help
Layson's has the lug nuts
Joe
Your in box is full. Would $12.00 shipped to you be fair for the 10 nuts?
Ken
