[WANTED] 8 3/4 rear axle housing for 1969 Dart
I have a '67 b-body housing which measures 59-1/2" whereas the stock a-body is 57-1/8". Is this will work for you, you can PM me.
Thanks,
David
the b-body rear end is too wide for the A-BODY, if used, you will need custom wheels
You will also need 8.75 shock plates and larger u-bolts
MOPAR CHARLIE
need an 8 3/4 rear end housing.
housing only.
I have 3rd member, axles and brakes ect.
I have one that the spring perches were moved. should be an easy put back. $270.00 plus shipping
PM with e-mail for pictures.
realize ur hunting a housing, but------------------
got one complete out of a 68 fast back,cleaned -painted black, 3:91 rear, traclok, :coffee2:2x10 rear brakes(need rebuilt-in box) sbp axles, will work w/3/4" offset spring hangers,or stock. Also comes w/ 2 14x6 glass beaded centerlines-look better than new. had it back in the car, decided to go w/ dana 60 because of big h.p.
in the tulsa area, $800 plus shipping, of could meet part way w/ deposit------------bob
i have just a bare housing also asking 300 plus the ride shipping prolly around 40.00 bucks
