I'm putting a rebuilt 8-3/4 rear end with 10" drum brakes in my 66 Valiant. I'm keeping the SBP wheels. My front brakes are getting swapped out for Kelsey Hayes discs which have been changed to all right hand thread studs. I want to change the studs on the left side of the rear end to RH thread also, but I'm having a very hard time finding something that matches the original studs.
My original studs are 7/16-20 with a .468 knurl diameter. If it makes a difference, the knurl has 23 splines. The rest of the dimensions are as follows:
A - .175"
B - .285"
C - 1.390"
I was able to find only 3 other RH studs, and they are close but not quite the same. Also .468 knurl diameter, but with 35 splines.
A - .185"
B - .280" knurl length, .405" total shoulder length
C - 1.380"
After a junk-yard scrounging trip looking for anything even vaguely close, I found a full set of 10 of these from a 89 Olds. Knurl diameter .468 with 29 splines.
A - .250"
B - .180" knurl length, .275" total shoulder length
C - 1.550"
My first choice is to find more of the original studs. If anyone has a full set to sell, please let me know.
It seems to me the second photo with the angled head is not as good a choice, as the shoulder is longer that the originals. Does this affect anything?
The round head studs from the Olds look to be a closer fit. If I have to use these, will the shorter knurl length make any difference in holding power so they don't twist inside the axle hole? Their longer overall length is not a problem, I have lots of room for a slightly longer stud.
Does the number of splines make any difference in the real world? It feels like the inside of the axle holes has indents that match the number of splines on the original studs. Perhaps I am overthinking this, but I don't want anything to go wrong as I head down the road.
A - .175"
B - .285"
C - 1.390"
A - .185"
C - 1.380"
A - .250"
C - 1.550"
