Can buy this cheap, but has some damage. Can see it in pic. Anybody have an opinion? Is is serviceable? What would it take to fix it ? It is a 3:23 Posi out of a 69 340 dart
From a performance view.Of the three, 489, 742 or 741 the 741 is the least desirable of the three.
I agree and have preached on here many times before that the weakling 741 pinion diameter is larger than the famed 9". I almost posted that again here but alas I didn't.Cool article comparing the 741, 742, 489 & even the 9" Ford at Pinion Comparison - Quality Body Shop Drivetrain
I mentioned before I'd used a 41 behind my 340 4spd, but I failed to say I used it with 4.30 gears, slicks, and 5k rpm launches at the track. I know when it's a good launch, when the glove box door flies open, all by itself, hahaha.Here's the way I always put it: Everybody knows that the Hemi is the best motor out there. And the 440 is a pretty good second place. But no one throws out a 383 because they are WEAKER than the others! A 741 case 8 3/4 will hold up to tons of abuse, especially with street tires. It's the old workhorse 383 that does the job for many budget racers! Sure a 440 or hemi is BETTER but the 383 is not a BOAT ANCHOR DOG! The biggest problem with the 741 is that there are not many new ring and pinion sets available for it. If you find one with the gear ratio you want, do NOT be afraid to use it on a street vehicle.
Your right. I'll say it again,I'll take all your junky *** 741's open or SG with 3.23's or 3.55's!All this fawning over the 741 case will only cause owners who may have one in a box of junk in the back of the garage that they couldn't give away at the swap meets to all of a sudden clean them up, and again carry from swap meet to swap meet unable to sell them because they now think they are something special!![]()
