8 3/4 to Dana 60
5.86?!? WTF?
A small block 55 Chevy driven on the street. I still have the gears. Bobby ran 6.17 in their F/Modified 64 Corvette. Chuck had a 833 trans in the 55 too. Bobby slick shifted that trans, can you imagine driving that on the street?
Initial mock-up shows we got the lengths correct in relation to the axles.
question / thought...
Are the axle bearing retainers in the position as if any backing plates / caliper mounts are installed that might move the bearing retainer out a bit?
Don't knock it til you've tried it! Just for shiggles I ran some 5.67's and a mini-spool in a 9" for a while....in a '77 Granada of all things.
I had a friend who drove a 283/4sp 57 chevy on the street with 5.13s
I first put my Tina together with 5.38s, (and 14x32 tires) and it was too much, even for 1/8 mile. (Small block). It was quicker and faster after I put in 4.57s
(I kinda assumed it was a very small cube modified production class car, to run east coast 1/8 mile. )
Almost everything on the west coast was 1/4 mile stuff. Would need LOTS of rpm to make that gear work in a quarter!
I had a friend who drove a 283/4sp on the street with 5.13s
The 68 Dart 440, 3100 pounds light, had 5.13s (538s one time but nothing changed) went thru 1/4 at 122 mph and 6800 rpm. 1/8 mile never got over 5000. My 70 Duster 340 running F/Stock will run 5.13s on 9x30 radials like all the other cars in the nation.
Tack welded, ready to trial fit to set pinion angle prior to welding perches on.
Ready for installation! A few delays due to life, raising a family, lol. I sure can't be accused of being fast on projects.
Sorry, did not see this before.
The axles were at correct installed width. I added washer stacks which were equivalent to brake drum thickness.
Do yourself a favor and run a piece of flat iron front and back on each perch to the housing. I’ve seen perches rip off and cause all kinds of problems. Kim
