moparmat2000
hi all
i posted a thread on here about the mopar 8.75 axle VS the ford explorer disc brake rear. well its settled i got an 8.75 from a 67 newport with a 742 center chunk 3.23 gears complete drum to drum for $100. price was always a consideration but trying to keep it mostly mopar was also. so when this one popped up with a 742 chunk i bought it.
so heres the big question, does anybody know where i can send the housing out to get it narrowed to a stock A body width, along with perches welded in. i can do the perches myself if need be, but the narrowing needs to be done with a jig to keep it all square.
also what is the stock pinion angle for this setup in an A body if i have to put the perches in myself?
what is the stock length of an A body 8.75" axle from backing plate flange to backing plate flange?
i plan on using new A body BBP axles with green bearings from mancini racing unless i can get my C body ones cut and resplined. anybody know where i can get the resplining done
can i use the 10.50" drums and backing plates off the 74 dart V8 rear axle?? its a 7.25" axle but the mating flange pattern for the backing plates looks to be the same pattern. the 11.0" diameter drums off the C body look to be a little large for this setup.
if you want you can post here but also please email me privately at moparmat2000@aol.com as i am not on here often enough to get the posts.
thanks
matt
thanks
matt
