pishta
I know I'm right....
Ring gear backlash: I see the .006 backlash and the method to get it, but what is the final torque spec of the adjusters? I saw 75 ft/lbs somewhere and wondered how that was accomplished. Some sort of 2.5 inch socket that has some teeth ground out of the walls? I see the adjuster pliers but there is no way to measure torque on those, Look like ring spreaders with pins on the end.
