cuda guy
- Joined
- Oct 15, 2009
- Messages
- 496
- Reaction score
- 33
What about a fox body rear end will they fir into a Duster or Demon
There's a little more work to put a Fox body into an A-body, most go with a explorer due to their 31 spline axles and the fact that they just about mount in with only some slight mods without having to cut down.What about a fox body rear end will they fir into a Duster or Demon
I heard about b body rear fitting an a body. What's up with that? My 60 is out of a 3/4 ton dodge truck with small tubes. Got a 4:10 in it and a 3:54 also. So I gotta rework it anyway. Tryin to save money.thx guys
I will stick with my b body rear and just work on the backspacing
Moving perches is no big deal. What size offset? I'm assuming you mean less than the standard 4.25 for an 8" rim?You have to move the spring perches and get rims with less off set
Friend of mine has a 79 Fairmont that runs mid 9's with nitrous and has an 8.8 and no problems.Anybody know the horsepower limits of the 8.8? Thinkin about putting it behind a 440.
Yep. was armed with that at the yard. Taught them a guys alot about explorer rear ends! Like looking at the tag. They didn't know it was on the door............Here’s 2 links that will help quite a bit when determining what you’re after when you got to the bone yard! One is for door codes the other is the rear end tag in case the either the door or rear end is not original to the Xploder!
Hope this helps!!!
Ford 7.5 & 8.8 Inch Axle Tag & Door Codes
Ford Rear Axle Assembly Identification - Page 13 - FORDification.com
I know I keep scrounging local pawn shops and eBay for one myself so it will cut that perfect V notch for welding it back together!!!!FYI since Harbor Freight doesn't sell the number 3 pipe cutter anymore I looked on eBay. Picked up a number two and number three for $11. They look old but are supposed to be in good shape. We shall see.
It will not give you a V notch you should still grind the ends for a V groove the housing is still pretty thick. But it will be straight.I know I keep scrounging local pawn shops and eBay for one myself so it will cut that perfect V notch for welding it back together!!!!
Ok, l have a 67 cuda as well. Bet you had to build a new floor for that 545rfe tranny. I'm thinkin gear vendors and 727 for me.I tried to install it but my driveshaft angle was too far off for my liking and the perches definitely didn’t line up. I have a 67 Barracuda with the 5.7 and 545rfe trans. So my drive shaft is definitely shorter than the original which my be the reason for the shaft angle. My thoughts are to try it before you cut it.
