Well Damn! Thanks everyone. The only reason I asked is I found 2 of them locally to me and the price was right, but Im not getting involved with trying to mod something that shouldnt be
I don't have details handy but I know its not so hard to do.Plans for a shifter adapter plate are out there. Not sure if they are all OD but they are often used for that benefit. The OD version is somewhat weaker due to how power is routed but likely only a factor if planning high HP and running it hard. I plan to try one out. If it lives the OD will be nice.
The transmission itself is a direct bolt in swap regarding the bellhousing. You will have to fab up a shifter relocation bracket to reposition the shifter and possibly do some work to the cross member if there is any interference there. Although the truck transmissions are CLOSE to the B and E body transmissions, they are not the same.
All of the 833's that came in trucks were overdrive transmissions, so 833OD's. They're all the B/E type tail housing, and most, if not all of them would have aluminum cases. The bearing retainer would be the 5.125" 833OD size just like the car OD's. Only difference with the truck 833OD's compared to cars is that they have a .71 4th gear instead of a .74, and they're all the B/E style tailshaft/housing.
As far as the "price being right", 833OD truck transmissions only get about $250 in top condition around here. I've bought several for $100 to $150 in good working condition.
The OD would be very nice on the freeway, but the remaining 3 gears will be suboptimal for 'spirited' acceleration. You would essentially be going to a 3 speed without the advantage of a torque converter. So think that out....
