9 1/8 clutch 1964 barracuda
ryan1964
California
Looking to replace my clutch it's the 9 1/8 someone one here had told me the summit replacement part number and now I can't find it any help would be great
Thank you and this works with the flywheel that I already have for the 9 1/8 clutch
Ok cool thank you I bought the rockauto one and it doesn't hold it will slip if I get on it
The Zoom should be a tougher clutch. If it slipps, contact Brewer preformance. They have some small ones that will hold 500 horse.
some of the rock auto discs are trash. i've had good luck with sachs, luk and zoom. if you only do a disc, make sure your pressure plate springs are tired and the surface of that and the flywheel are good otherwise you'll just be in the same boat again.
i've run the sachs and zoom with 375~400hp and not had a problem. the luk i only ran on a slightly hotter 318 and beat the snot out of it for years without any complaints.
