ryan1964
Looking to replace my clutch it's the 9 1/8 someone one here had told me the summit replacement part number and now I can't find it any help would be great
It should be a scalloped pressure plate that bolts to the small flywheel.Thank you and this works with the flywheel that I already have for the 9 1/8 clutch
it works with the stock 122T flywheelThank you and this works with the flywheel that I already have for the 9 1/8 clutch
The Zoom should be a tougher clutch. If it slipps, contact Brewer preformance. They have some small ones that will hold 500 horse.Ok cool thank you I bought the rockauto one and it doesn't hold it will slip if I get on it
some of the rock auto discs are trash. i've had good luck with sachs, luk and zoom. if you only do a disc, make sure your pressure plate springs are tired and the surface of that and the flywheel are good otherwise you'll just be in the same boat again.Ok cool thank you I bought the rockauto one and it doesn't hold it will slip if I get on it
It's just a mild stock bore 318 still pretty strong thoughThe Zoom should be a tougher clutch. If it slipps, contact Brewer preformance. They have some small ones that will hold 500 horse.
