9.88 with my little magnum
motorcitymagnum
metro detroit
had duster out yesterday for a little testing
i havent posted in a while but combo is listed if you search
9.88 @ 134 she has more in it. ill post pics later
motorcitymagnum
thanks fella's yes i run at lapeer and milan. just a little 200 shot with n2o.
be working on getting consistent times. minor changes over winter
obviously not fastest duster on site but for what is in it,im very happy.
very soft 60' (same as last year and year before) mph is tad slower but thats ok.
just having fun saving up some cash so i can compete with grudge/no prep crowd hopefully! mopar powered of course!
If you're happy and having fun with it, what else is there?
:thumbsup:
Nice work, I thought about going out to watch some testing at Lapeer Sat or Sun.
weather was cool and damp as usual. had a good car count.
valiants hopefully milan will open soon and im sure ill see you there. are you going to run the heads up series? 9secrr i use a nx controller set at 20% then full on at 1 sec. seems to be best setting
quick little update
since Milan is back open, went this past Saturday for fun(tnt)
heat off the day went 9.80
first pass 9.88
only had time for 2 hits. family is visiting so ill post video later
quick little update
first pass 9.88
That’s awesome ! I have been running a 5.9 Magnum short block with W2 heads for years , went 10.70s with a basically stock bottom end , 10.40s with same block and better bottom end all with a 590 lift cam , it now runs 10.80s at 9.5 to 1 compression on pump gas with a stroker kit at 410 cubic inches
thanks for the reply! it doesn't take a whole lot to make magnums run
my duster is very streetable if you like driving around with no ac.
