904 automatic
dennyscuda
New Member
pa
i have a 904 automatic that i think came out of a belvedere but cannot find the id numbers on computer, the numbers on tranny just above oil pan are 2466122w 1643095 ,the tail shaft is 18 " long and the bolt pattern for mount has 4 " center where the cuda and valiant has a 2 1/4 center. can anyone tell me what this came out of or a site that i can look them up, thanks
[ame]http://www.mymopar.com/downloads/transguide.pdf[/ame]
Use this guide to help you with any other tranny ID number identification in furture.
Larger trans mount center to center are for C-B-body and truck use.What type of tail shaft does it have,slip in type trunion,bolt in? can you post a picture of the tranny and the ID numbers on oil pan rail? Since this is a 1965 unit,what shifter type is it using ,cable or lever type,mrmopartech
