i have a 408 stroker that is going in my valiant. i originally planned on a stock 360 but as usual things got out of hand. the 904 that i bought for the 360 is a brand new rebuild. not sure on the specs, but the trans guy i bought it from said it was stronger than the stock 318 904. im just wondering with the durastic change in horsepower whether the trans will work in this configuration. i still have the original 904 bolted to the 318 and can rebuild that if needed. i would also consider other transmissions with more gears. gotta be pretty close to bolt in though as i dont want to do any crazy mods. any advice?
the car is a 4dr fully loaded up, and will see mostly street use. 408, with 8 3/4 rear with undecided rear gear.
im also debating what a good rear gear size would be
