Sean Mooney
Active Member
just disassembled a 904 to check it over and found the front clutch clearance (5clutch drum)was only .042. Is this too tight and if so would it cause a noise when cold and put in reverse as this is the only problem with the tranny. Other than that it shifts good. Also clutch friction disks show no sign of wear.
Thanks
Sean
Thanks
Sean
