904 Tail Shaft Seal Selection?
from fabo archivies dated 1/15/2013. 3515852 is a 904 with damper weighted provisions. it fits 1971 a, b and e body 318.
My dart's trans was rebuilt in the mid 80s it had a flat rear seal like in the photo post 29.
It was leaking so I replaced it with the bellows type.
Unfortunately the seal is just long enough that the bellows end touches the up curve of the yoke more than I would like. But at 1000 to 2000 miles per year I suspect it will last my lifetime
I would’ve preferred the seal with the boot. However, the OD of the seal would’ve been too large for the tail shaft housing bore
The 8835S (both the National and Timken part number) along with ATP TO15 are booted seals with the 2.254" OD. Simple parts-store stuff.
Unfortunately my local parts store did not have them in stock. I’ll write that down for future use though
