904 trans identification
wes beem
ohio
Picked up this 904 last night, seller didnt know anything about it, wanting to buy a performance full rebuild kit so i need to know the year range.
Thanks guys! Will that converter work with a stock spec 360 magnum?
I believe it would.... BTW, keep converter with trans....they are made to work together, meaning you cant mix those parts with other trannies. A lockup converter goes with a lockup trans (and vb).
from what i read today it Looks like all i need to run it is a weighted magnum flexplate.
Hey Wes,
can you please count the splines on the input shaft for me? Curious about the spline count on a lock up input shaft.
Thanks!
Should be 26, and the splines are not cut all the way out to the end.
HTH
