904 Trans Struggle Bus
GibsonR
New Member
St. Louis Metro Missouri
New to the Mopar world, my teenage son drug me in kicking and screaming with his inherited 69 D100 and recent purchase of a 66 Dart. The issue is related to the Dart. Slant Six car in pretty darn good condition but when we parked it for a few days I noticed a decent puddle of trans fluid so we got a gasket and had him pull the pan to replace. When he went to bolt the pan back up turns out someone got overly excited at some point and mangled the threads on 10 of the bolt holes and had put in heli-coils to try and save it and well…. Not good. Me not knowing anything about these cars and the particulars bought another 904 that turned out to be a small block bellhousing, was super cheap and we had considered swapping in a 318 we have so I figured no harm no foul. Found another slant six bellhousing 904 that had come out of a running driving car very recently and after carefully ensuring each bolt would hold 15 lbs of torque we set to getting it ready to go in the car (some of you probably have already guessed where this is going). Lesson #2 learned, the input shafts on the trans are different for the later 904’s and of course what we have is a later model so the torque converter would not go on. I had bought time-serts and contemplated fixing the original trans but would much prefer a non mangled case. Now the question is, can we strip out the newer case and get a rebuild kit and put the parts from the original trans, most importantly the pump housing and input shaft, into the newer case? I also read that the neutral safety/backup light switch is valve body specific so would have likely had issues with that as well. If moving things over is a feasible path is there a preferred vendor for a rebuild kit?
Where did you come up with that torque spec for the pan bolts? You'll cut the gasket all to pieces. Should be like 9-12 LB FT.
You’re right, it was 10-12. The spec was 150 inch pounds so 10 the first round and 12 the second, I just had the 15 in my head and was thinking 10 first 15 second but he confirmed it was 12.
Thought... Could you drill out the mangled threads, tap them the next larger thread?
I would have non-issue on using properly installed inserts on the pan bolts
I'm nobody's idea of an expert, but...
When I do an oil pan, trans pan, or valve cover gasket first thing after cleanup is set the pan flange on a 2x4 or 2x6 laid long ways on edge, exterior facing down. An extra set of hands helps a lot here. Then take about an 6" long piece of 1/2" wooden dowel and GENTLY tap with a hammer to flatten the bolt holes so it will seal. You are flattening from the inside, and gorillas need not apply for this job.
To tighten on install, don't use a 3/8 torque wrench set at 10#. Those settings are too coarse down that low - use a 1/4" drive using the correct inch pounds. Watch the gasket as you snug it down. The most it should do is VERY SLIGHTLY pooch out at the bolt holes.
EDIT:
Sorry, the wood should be a 1x6 so it fits between the pan and flange.
As those cases age they get porosity in them. I would use the newer trans since your planing on a 318 anyway. Keep the valve body and only use the center pin for neutral safety. With the later trans you can then enjoy the use of a part throttle kick down valve.
For now have a machine shop turn down the converter register hub. They make a bushing to go back to a big register if you decide update the engine.
Is there a difference in the torque converters for the 318’s vs. the Slant Six? There is someone near me that has one from a 69 904 but it was a 318 car.
The last time I read the service manual (online) I recall the first paragraph of the automatic transmission was about - how to drill, tap, insert a helicoil for stripped threads. The first paragraph!
(Edited: meaning, it is very common to strip the threads.)
I'm trying to find the service manual for the automatic transmissions - looking for the torque spec for the pan bolts.
The answer is in the above posts, & for a manual, hard to beat Member @VOETOM 's book on the the Torqueflite. SA Design Books, Tom Hand, SA394.
