70-duster
i have a 70 duster that I am converting from a column shift to a floor shift. Are the brackets and rod different between a 727 and 904? I can't get anything to line up.
Here is what I have.There are many different console automatic linkage pieces for A, B, C and E-Body and 67-76 are not the same for all models. Post some pics if you can of what you have so we can help you figure it out
The bracket 19-48-46 is giving me the issue. It rod that is suppose to go through it,is not in the hole. It is like 1/2" above the bracket. I tried bending the bracket, but that made it worse. I ended up adding 2" to the bottom of the rod. I think some of my issue is the location of the center console brackets on the interior too. Is there a picture with dimensions on where EXACTLY the brackets get welded?
