swing69
fightin' socialism
I know that the lever action 904 will fit perfectly behind the 360 in our old 64 Dart. We are going to install a 66 stock console shifter into the 64. That way, we'll have a lever shift trans. rather than a cable shift.
Question: The 727 is physicall larger at the tunnel, so I know the tunnel/cowl seam will need to be beaten flat. But are there any other fit issues? we're going to build a 8.75, so I know a new driveshaft will be needed, so I really don't care about the tailshaft length (if that is an issue)
thanks
thanks
