mycuda
Hi, What oil pan do I need for swap in 65 Dart. This pan obviously will hit steering assembly.
Thanks in advance.
Dave
Thanks in advance.
Dave
Yes do have one but seems 4spd trans to engine bolts together closer to firewall? Dont know, just gettin input.I'm not sure the pan is the problem. Do you have a V8 steering/center link?
That pan you have will definately workMy friend and I put a 94 318 magnum into a 71 demon. You need a 360 pan for a car and it'll go right in. We used a Kevko, but it doesn't matter.
Are you SURE? just because it fit a Demon does not mean it fits the early A's.My friend and I put a 94 318 magnum into a 71 demon. You need a 360 pan for a car and it'll go right in. We used a Kevko, but it doesn't matter.
This isn't correct either. It has to be a 360 car oil pan.If you use any car oil pan with a center sump you should have no issues.
You will have to use different motor mounts or use can modify the early A V8 motor mounts, it's not that hard.
I was pointing out if it's a center sump it fit.This isn't correct either. It has to be a 360 car oil pan.
