Confusedcuda
Does anybody know what the flow numbers are on the 67 920 heads and the 302 heads. Runner difference, Combustion Chamber volume etc. Thanks
copied from shadydells website...
LIFT-------AS CAST------PORTED
.100”-----51.8/N/A--------71.8/N/A
.200”-----92.5/70.7--------148.4/86.3
.300”-----130.1/104.3-----212.2/113.9
.400”-----163.9/113.2-----241.5/131.1
.450”-----169.1/115.2-----244.6/137.7
.500”-----170.4/117.3-----246.7/139.7
.550”-----172.2/119.0-----242.6/144.9
.600”-----172.5/120.4-----240.8/144.9
All #’s at 28” of water
No flow tube on exhaust
As cast #’s are 1.78”/1.50” valves, Ported is with 2.02”/1.60” Ferrea 5000 Series, No Back Cut.
Ported Intake Runner Volume is 151 CC’s
yup, i ant ever seen any numbers for the 920sBut which casting is that? I assume the 302?
And factory 2.02 360 had is 155 cc.. while factory 1.88 is 160cc. Yes, the factory 2.02 tulip valve eats that much bowl volume...copied from shadydells website...302 flow numbers!
BAMM BABY!Really the difference between the 2 is marginal
Good info guys. Please help me with those flow numbers tho! What do those numbers mean or represent? Obviously lift is the amount the valve is opened but what is the 2 sets of numbers intake/exhaust? And what does the number represent? How much water will flow thru in a given amount of time? Thanks sorry for stupid questions I'm still learning the performance side of things
Were the 920's a CAP head? Why did the DDarts use them.My Dart running in D/S back in 1966 ran a best of 12.92 and 105 mph. This was with stock 920 heads, 7" wide slicks and rosin. The car was launched and shifter at from 6700 to 6900 rpm's. So the stock 920 heads are pretty good. I believe the car was only run competitively in 1966.
