9in under a 74 Dart Swinger!
OlRustyCrank
Active Member
SC
I have a 74 Swinger and I also have a 66 Bronco that's rusted out. I've done some research and found that the 9in is less than an inch wider than the 8 3/4 for an a-body. I would have to do a pad flip for the springs and probably move them in some.
My question is this, does it have the off center issue that the 8.8 has?
Oh, one more thing, it has a 4.11 gears in it.
Thanks for the response. I will lay them side by side once I get them out.
I run a Lincoln Versailles 9" under mine, factory disk brakes. I would not use those brakes "again" as parts are hard to find. It is a bit wider, but I ran Mustang " Bullitt" wheels and they bolt right on. There are two (at least) offset of those wheels, I forget which ones I have
