Car is a 73 dart sport. Discs in front drums rear, the PO was converting the car to a drag setup about 10-12 years ago when he moved and all progress on the car stopped(thankfully as it was a hack job). The front brakes were locked on but I found a line lock device hooked up but unpowered, giving it power managed to free one of the fronts. The rears locked up as well. I want to eliminate the line lock and hook everything back up how it is supposed to be but am clueless on how the lines are supposed to run as currently 2 lines come from the master, 1 going to the passenger side where it is T'd off going to the line lock on the drivers firewall, from that into a box(proportioning valve?) that runs to the drivers side and back to the line lock. The other heads to the rear I believe, but at the axle the line again is T'd off feeding both sides.
I am planning on buying a new lines, proportioning valve, master, calipers, rotors, pads and for the rear I imagine replacing the drums and brakes. How are the lines supposed to run? Is that box deal the proportioning valve? It confuses me as the power out from the line lock is running to it.
thanks
thanks
